AllWin
May 23, 2012Aspirant
Feedback on ReadyNAS Duo v2
Hi, recently i bought Netgear ReadyNAS Duo V2 device, so i thought i will share my experiences so far. I'll be as short as possible. The good. - Excellent performance! I get 41-50 MB/s write and 7...
Jul 17, 2012Guru - Experienced User
I don't have a v2 (neither does PapaBear). With the v1 and X86 platforms, there is a check-off box in FrontView backup that optionally deletes backup files that are no longer on the source.
techman05 wrote: I'd also wonder with the rsync comment that wouldn't deleting from the main device delete from the secondary backup device :shock: ? If something non data oops happens this would work but normal deletion I'd think no.
My daily backup jobs don't have this option selected (also Frontview does not delete these files by default).
Every now and then I check it, and run a backup manually to delete old files.
