markg1
Mar 19, 2012Aspirant
Feedback on ReadyNAS Pro 6 problem
i have a 6 month old ReadyNAS Pro 6, in addition to a ReadyNAS Pro Biz and ReadyNAS NV+ which are much older. they have all worked flawlessly throughout their lives, with a few software issues here a...
PapaBear1
Mar 21, 2012Apprentice
Newegg has three 120MM fans listed that are close. Two are 2200 RPM, one is a 3/4 wiring connection but the other is only two wire. There is also a 2100 RPM fan with a four wire molex connector. They have 16 120MM fans listed that are 2000 RPM but I did not look at them. This one seems to be the closest (and the least expensive). For $14 it may be worth the shot if it will get the unit back in service while you work with Tech Support.
