rit1
Nov 09, 2013Aspirant
Feedback regarding 104 device
I've just purchased a 104, to be honest the reason being that at least in the UK the street price is now so low that it undercuts all other 4 drive devices. On install it correctly upgraded to the ...
rit1
Nov 11, 2013Aspirant
Thanks for the quick reply
>>70 hours is too long for Raid building on RN104 with 3x2TB disks, are you using RN104 now?
>>Please enable SSH and access NAS via SSH, then you can see process using top command.
After doing this I found that with no file I/O going to the device that smbd was runing at a constant 90% load. To remove this I disabled SMB support via the GUI, and after I waited about 15s the demon dropped out of the top list. When I turned SMB back on it did not generate the same level of load (so the rebuild is now a lot faster)- this indicates that the smbd process itself was having an unknown problem.
>>When SMART page is display, you can move your mouse to SMART message, then you may move information up and down using mouse wheel.
OK I was able to do this from my desktop, but its a poor design as other brower based devices may not have easy access to such 'actions'.
>>Is it IPv6 link-local address?
The issue for me is that for both IPv4 and IPv6 it should be possible to state do not use, at the moment the options are set via a static entry or DHCP. As the device is going into an R&D LAN its key to know the exact state of such things, and to be able to make sure they do not change or get in the way of other tests.
Thanks again
Roger
Thanks again
Roger
