rit1
Nov 09, 2013Aspirant
Feedback regarding 104 device
I've just purchased a 104, to be honest the reason being that at least in the UK the street price is now so low that it undercuts all other 4 drive devices. On install it correctly upgraded to the ...
rit1
Nov 12, 2013Aspirant
Lastest report from this deployment
All 4 disks were correctly configured as a single RAID 5 XRAID volume, so I then went to change the MTU to 9000. Once changed the 104 lost it's IP setting (which is static), so the device became uncontactable across my network.
Also the mult-press shut down via the front panel switch did not work so I (again) had to pull the plug. It is now rebuilding the lastest disk again, so another 10 hours or so to wait.
