rit1
Nov 09, 2013Aspirant
Feedback regarding 104 device
I've just purchased a 104, to be honest the reason being that at least in the UK the street price is now so low that it undercuts all other 4 drive devices. On install it correctly upgraded to the ...
Nov 27, 2013Guru - Experienced User
Agreed. Depending on a mouse wheel being present is a horrible design.
nickbatch wrote: Re post from Evan
- On the disk view under System/Performance/Status/Disk the window displayed to show the stats of a disk drive is too small so you can not see all the SMART information
=> When SMART page is display, you can move your mouse to SMART message, then you may move information up and down using mouse wheel.
This may work with a mouse with a wheel but not with dell laptop using touchpad This requires an alternative solution.
