squirrelva
Aug 13, 2011Follower
File formats
Hi,
New to this so excuse ignorance.
Just bought Netgear ReadyNAS DUO 2TB.
Can I store / use any audio file formats ? Just read somewhere that it might only be MP3.
Mark
Mark
1 Reply
- Mr47AspirantThis is the wrong subforum to post in I believe, but here goes anyway.
You can store any file format you like on the ReadyNAS system; the box does not care whatsoever what you put on it, even if it is a bunch of random bits.
So yes, you can use it to store any audio file and read them back on any device which has access to the readyNas.
