landogarner
Sep 28, 2007Aspirant
File Manager inside Readynas
It would be nice to be able to do file manipulations directly inside ReadyNAS GUI.
We have millions of files on our ReadyNAS that come from security cameras and it takes hours to delete them over LAN access with high LAN load during this period.
I think it would be much faster to select the files to be deleted inside the ReadyNAS GUI and then let it do the job.
Any chance for implementing this feature ?
Thanks.
Thanks.
- yoh-dahGuide
MarkusB wrote: yoh-dah wrote: There is a built-in HTTP file manager. Just enable write access over HTTP and you can connect to http://<readynas> and do your magic. 8)
So I enabled write access over HTTP. Logged in as admin and then I can see all the shares I enabled write access. I click through the tree to the directory, where I have some undeletable files. So far great.
But: It doesn't show any files in all directories (they are there, for sure).
Help says:
"Why does the file manager seem broken in certain directories or when copying or pasting certain files?
This occurs when the web file manager does not have permission to access these files. You must access these files via another method."
Nice, there is a built-in HTTP file manager, but if I want to use it, I have to use "another method". :D
Is there a way to get the permission?
Regards
Markus
The HTTP file manager will run as user "admin" even if you logged in as another user. It's a limitation due to the service. But the effect is if the file is owned by another user and "admin" does not have access to it, you'll have some problems. Perhaps try using dbott67's suggestion of using a FTP or SCP client. For SCP, you would need to enable SSH support however. - looterAspirant[/quote]
The HTTP file manager will run as user "admin" even if you logged in as another user. It's a limitation due to the service. But the effect is if the file is owned by another user and "admin" does not have access to it, you'll have some problems. Perhaps try using dbott67's suggestion of using a FTP or SCP client. For SCP, you would need to enable SSH support however.[/quote]
Any way to access a private home share via HTTP file manager? - nfjanetteAspirant+1 on the request.
The existing http file browser is limited to working with shares on that box. This doesn't cover what I'd like to be able to do: copy files from another (non-readyNAS without rsync support) NAS onto a ReadyNAS without the read/write overhead passed through a desktop client system. If this was available, I could also then use the second interfaces on an 1100 box (and the other NAS) to keep traffic off of the production LAN. - Ummm..... +1 on the internal file manager.
- super_poussinVirtuoso
Mon1018 wrote: Ummm..... +1 on the internal file manager.
Did you take a look on PHP Advanced Transfer Manager (PHP ATM) ?
http://phpatm.org/
It works on the ready Nas :) - cdeelAspirant@super-poussin:
I tried your suggestion of phpATM, and got it running (more or less). I installed it into its own "phpATM" share.
I think I'm missing one fundamental point: how did you configure it to offer your files for download? Say I wanted to make the whole contents of my "media" share available via phpATM. Would you install phpATM into the root of the "media" share? Or do something with symbolic links to make the "media" files available?
Thanks for any help! - looterAspirant
super-poussin wrote: Mon1018 wrote: Ummm..... +1 on the internal file manager.
http://phpatm.org/
Sounds great!
Any one got a quick 'Installing and Enabling PHP and then PHP ATM on a ReadyNAS for dummies'?
Seriously?
Thanks - super_poussinVirtuosoI will redo the installation and post an howto :)
- looterAspirant
super-poussin wrote: I will redo the installation and post an howto :)
That would be great!
Thanks :) - super_poussinVirtuosophpatm is not easy to configure :) needs a lot of cutomization in php.ini and config files
working on another product which sounds good stay tuned (in ajax)
