Manuel_Baena
Nov 20, 2018Aspirant
Filesystem still has errors (ReadyNAS 3200)
Hello, I have ReadyNAS 3200 with data volume failures.
After a disk failed, the server restarted and after running automatic checks, it was unable to recover the volume data system.
I put...
Nov 23, 2018Guru - Experienced User
I think you will need data recovery. Netgear has a recovery service here: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
You could also connect the disks to a Windows PC and try R-Studio for Windows. https://www.r-studio.com/
- Manuel_BaenaDec 10, 2018Aspirant
How can I get int touch with technical support? Through the link (https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service) I don't get any email to contact or other contact form.
- StephenBDec 10, 2018Guru - Experienced User
my.netgear.com is the place to start for all paid support requests. You don't want Gearhead, you want to go into the registration page and ask for support for your registered ReadyNAS.
Ok, thanks
