corkscrew22
Sep 12, 2021Aspirant
filezilla
I am trying to connect to my ReadyNAS Duo v1 with filezilla, see the attached screen shots. I am using the admin log in and password. It appears to be connecting ok but will not get a directory ...
- Sep 14, 2021
corkscrew22 wrote:
here are the ftp settings in screenshots below
This one needs to be set to passive, not active.
corkscrew22
Sep 13, 2021Aspirant
ok lot of questions comments below is more info
the duo and the desktop are both on local network going through a manged switch and a router.
It is worth noting I have a raspberry pi on the same network and I can connect to it from the same desktop using filezilla and ftp and works fine so i dont believe there are any firewall isues.
I am connecting using standard ftp.
as for Masquerade settings I had it set to the below first
This did not work and as mentioned it is not required so i set back to the default see below
So i then try to connect using these settings
Host ftp://192.168.2.9, username and password i leave blank , Port i put 21, the result is pretty much the same as before from what i can see it connects but cannot retrieve a directory listing.
Sep 14, 2021Guru - Experienced User
- corkscrew22Sep 14, 2021Aspirant
thanks very much working fine now...
