mahfooz
May 06, 2017Aspirant
Firmware 6.7.1 Broken my 1 Network Interface and lots of other problems
I have updated my firmware and got following problems 1- It has broken 1 of my network interface. 2- I am unable to see any available apps. 3- I was unable to turn off ready cloud 4- Clicking on ...
- May 21, 2017
1) How do I point it myself to the correct drive should this happen again ?
1. Create new .apps and home subvolume in new volume, (For example, MyData is new volume)
a. Access NAS via SSH, then run below two commands,
btrfs subvol create /MyData/.apps
btrfs subvol create /MyData/Home
2. /lib/systemd/system/apps.mount and /lib/systemd/system/home.mount were pointing to the NEW volume using vimtiny command, (For example, MyData is new volume in below config)
root@NAS:/# cd /lib/systemd/system
root@NAS:/lib/systemd/system# cat apps.mount
[Unit]
Description=Apps Directory
After=local-fs.target
Before=multi-user.target[Mount]
What=/MyData/.apps
Where=/apps
Type=none
Options=bind[Install]
WantedBy=multi-user.target
root@NAS:/lib/systemd/system# cat home.mount
[Unit]
Description=Home Directory
What=/MyData/home
Where=/home
Type=none
root@NAS:/lib/systemd/system#3. Run OS Reinstall,
2) Should I not use my previous saved config file ? (last time I used this file and it has braked everything again)
You can't restore old config file because mount path is changed, if use old config, it will point to old volume in config file.
mdgm-ntgr
May 06, 2017NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
mahfooz
| Sun May 7 2017 11:37:17 | System: Host name was changed to NAS. | |
| Sun May 7 2017 11:20:50 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 11:20:19 | System: External storage device connected. | |
| Sun May 7 2017 11:20:18 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 11:20:13 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 11:14:15 | System: The system is shutting down. | |
| Sun May 7 2017 11:13:47 | System: ReadyNAS configuration restored. Reboot this system for the changes to take effect. | |
| Sun May 7 2017 11:07:20 | System: External storage device connected. | |
| Sun May 7 2017 11:06:08 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 11:05:51 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 11:05:45 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 10:51:31 | System: The system is shutting down. | |
| Sun May 7 2017 10:46:43 | Account: User 'asad.ae@gmail.com' was deleted. | |
| Sun May 7 2017 10:46:40 | Account: User 'amahfooz@gmail.com' was deleted. | |
| Sun May 7 2017 10:37:14 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 10:36:53 | System: Firmware was upgraded to 6.7.1. | |
| Sun May 7 2017 10:36:57 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 10:36:51 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 10:30:01 | System: The system is shutting down. | |
| Sun May 7 2017 10:12:46 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 10:12:10 | System: Firmware was upgraded to 6.7.1. | |
| Sun May 7 2017 10:12:14 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 10:12:14 | System: External storage device connected. | |
| Sun May 7 2017 10:12:09 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 10:06:17 | System: The system is rebooting. | |
| Sun May 7 2017 9:54:57 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 9:54:29 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. |
| Sun May 7 2017 9:54:29 | System: External storage device connected. |
| Sun May 7 2017 9:54:24 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 9:47:19 | System: The system is shutting down. | |
| Sun May 7 2017 9:35:29 | System: Cannot install application vpnserver. | |
| Sun May 7 2017 9:35:24 | Share: Share vpnserver was added. | |
| Sun May 7 2017 9:30:07 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 9:29:36 | System: External storage device connected. | |
| Sun May 7 2017 9:29:36 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 9:29:31 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 9:25:19 | System: The system is rebooting. | |
| Sun May 7 2017 8:56:16 | System: ReadyNASOS background service started. | |
| Sun May 7 2017 8:53:36 | Volume: Less than 5% of volume WDREDNEW's capacity is free. Performance on volume WDREDNEW is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 8:52:33 | System: Firmware was upgraded to 6.7.1. | |
| Sun May 7 2017 8:52:35 | System: External storage device connected. | |
| Sun May 7 2017 8:52:30 | Volume: Less than 5% of volume SEAGATE4TB's capacity is free. Performance on volume SEAGATE4TB is degraded. To improve performance, you must add capacity. | |
| Sun May 7 2017 8:48:34 | System: The system is rebooting. | |
| Sun May 7 2017 0:05:04 | Snapshot: Snapshot prune worker successfully deleted snapshot 2017_04_09__00_00_28 from share or LUN MyData. | |
| Sun May 7 2017 0:05:02 | Snapshot: Snapshot prune worker successfully deleted snapshot 2017_04_09__00_00_28 from share or LUN KidStuff. | |
| Sun May 7 2017 0:00:25 | Miscellaneous: Snapshot c_1494072000 was successfully created for share or LUN WD2TB. | |
| Sun May 7 2017 0:00:24 | Miscellaneous: Snapshot c_1494072000 was successfully created for share or LUN MyData. | |
| Sun May 7 2017 0:00:14 | Miscellaneous: Snapshot c_1494072000 was successfully created for share or LUN KidStuff. |
| Sat May 6 2017 0:00:29 | Miscellaneous: Snapshot c_1493985609 was successfully created for share or LUN WD2TB. | |
| Sat May 6 2017 0:00:28 | Miscellaneous: Snapshot c_1493985609 was successfully created for share or LUN MyData. | |
| Sat May 6 2017 0:00:16 | Miscellaneous: Snapshot c_1493985609 was successfully created for share or LUN KidStuff. | |
- mdgm-ntgrMay 06, 2017NETGEAR Employee Retired
That's the status log. The Sending Logs link in my sig explains how to download the logs and send the zip file in.
From your status log I can see that you have some very full data volumes.
- mahfoozMay 06, 2017Aspirant
sorry for that.
I have sent zip file to the email address and attn:mdgm.
Thanks a lot for looking into my issue
- mahfoozMay 07, 2017Aspirant
This is the error message
This is the error message intermittant keep on coming was fixed couple of hours ago by it's self but started doing again now
but that is wrong...........see picture below in cloud section
