mahfooz
May 06, 2017Aspirant
Firmware 6.7.1 Broken my 1 Network Interface and lots of other problems
I have updated my firmware and got following problems 1- It has broken 1 of my network interface. 2- I am unable to see any available apps. 3- I was unable to turn off ready cloud 4- Clicking on ...
- May 21, 2017
1) How do I point it myself to the correct drive should this happen again ?
1. Create new .apps and home subvolume in new volume, (For example, MyData is new volume)
a. Access NAS via SSH, then run below two commands,
btrfs subvol create /MyData/.apps
btrfs subvol create /MyData/Home
2. /lib/systemd/system/apps.mount and /lib/systemd/system/home.mount were pointing to the NEW volume using vimtiny command, (For example, MyData is new volume in below config)
root@NAS:/# cd /lib/systemd/system
root@NAS:/lib/systemd/system# cat apps.mount
[Unit]
Description=Apps Directory
After=local-fs.target
Before=multi-user.target[Mount]
What=/MyData/.apps
Where=/apps
Type=none
Options=bind[Install]
WantedBy=multi-user.target
root@NAS:/lib/systemd/system# cat home.mount
[Unit]
Description=Home Directory
What=/MyData/home
Where=/home
Type=none
root@NAS:/lib/systemd/system#3. Run OS Reinstall,
2) Should I not use my previous saved config file ? (last time I used this file and it has braked everything again)
You can't restore old config file because mount path is changed, if use old config, it will point to old volume in config file.
jak0lantash
May 18, 2017Mentor
You're on a forum. Everyone is welcome to contribute.
You want to talk to NETGEAR Support? Contact NETGEAR Support.
You're angry because you know you messed up, that you shouldn't have restored that config file after somebody fixed your NAS. I get it. But it doesn't give you the right to use bad language.
Hugs and kisses.
Hugs and kisses.
mahfooz
May 18, 2017Aspirant
Brother, the way you open your conversation was really ugly and bad and illmanners.
but hi that is fine to yell if no one is listening ...............that's what a normal person do ...................... isn't it......
I am not angry due to I messed up................... I am angry that I was not told to not to do this as it will mess up............2 different scenario if you cable to understand that.
everyone is welcome to contribute but it's a bad manners to take the part when 2 people are talking................unless you will be asked to take the part.............it's just a matter of Manners which I believe not many people have no a days.
Go and try to interfere between when 2 people are having argument and you will not only hear bad language but also get kick as well most of the time.
When someone don't realize that he is getting illmanners than this is how you will try to explain them............using bad language.
Lots of Hugs, Kisses, well wishes and good luck.
- mahfoozMay 18, 2017Aspirant
Still no one there to help me?
- mdgm-ntgrMay 19, 2017NETGEAR Employee Retired
I've sent you a PM. I can take a look at your system if you like.
This is a community, not support. Provided they abide by our community rules anyone is free to contribute to the discussion. By sharing ideas and suggestions users can work collaboratively to resolve problems.
Whilst jak0lantash is no longer at NETGEAR he has a lot of experience working with these products and has helped other users on the community with valuable advice. He's coming on here in his free time to give his opinion.
As has been mentioned if you would rather use traditional support channels we do have that option available. Currently each new ReadyNAS purchase comes with 90 days of basic technical support with the option to extend this with a support contract.
Restoring a broken config was always going to end badly. With a broken config it's best to manually reconfigure.- mahfoozMay 19, 2017Aspirant
I did pm'ed you. Did you found my email?
