phrosty23
Jun 10, 2020Aspirant
Firmware Update Wipes Out Volume
Monday, I needed to power off my ReadyNAS as I was swapping out the batteries on my UPS. When I brought it back up, I saw the alert for the 6.10.3 firmware update, so I figured since it was after hou...
Jun 10, 2020Guru - Experienced User
Do you recall how you did that? Your symptoms suggest you did a "hard" (not clean) shutdown. Lost writes in the cache would then explain the volume becoming out of sync and not mounted.
Paid support is unfortunately the best path to remount it. Perhaps JohnCM_S or Marc_V can escalate your case.
phrosty23
The first shutdown was from the web Admin Page and going to the power button link, dropping down and selecting Shut Down.
Upon powering up and getting the notification of the firmware update, I proceeded to install the update and then do the reboot as instructed. So there was no hard shutdown.
