phrosty23
Jun 10, 2020Aspirant
Firmware Update Wipes Out Volume
Monday, I needed to power off my ReadyNAS as I was swapping out the batteries on my UPS. When I brought it back up, I saw the alert for the 6.10.3 firmware update, so I figured since it was after hou...
Jun 10, 2020Guru - Experienced User
Do you recall how you did that? Your symptoms suggest you did a "hard" (not clean) shutdown. Lost writes in the cache would then explain the volume becoming out of sync and not mounted.
Paid support is unfortunately the best path to remount it. Perhaps JohnCM_S or Marc_V can escalate your case.
phrosty23
The one person I have talked to out of probably 8 calls and 6 hours on hold was Stefan. He had me reboot into Tech Support mode, get the debut code and to let him know what it was. I have been trying to get back in touch with him or his group since Monday, but apparently making to Stefan the first time was like finding a leprechaun riding a unicorn.
I have no problem paying for support, I just can't seem to get ahold of anyone on the phone or through my support ticket.
