Lionel1020's avatar
Lionel1020
First time setup on a RND2000v2|ReadyNAS Duo
Hello one and all,   I am trying to set-up a RND2000v2|ReadyNAS Duo v2. Never installed a network storage unit before, please assume I know nothing as this is pretty near the truth. My aim is to c...
  • StephenB's avatar
    Dec 04, 2019
    Lionel1020 wrote:
    “Reallocated sector count has increased in the last day. Disk 1: Previous count: 17 Current count: 19 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
    [Tue Dec 3 04:00:02 PST 2019]”
    We might have found why we have a speed/copy problem!!!
    Yes.  I'd definitely replace the disk.
    If you had two disks installed, you could simply hot-swap it with a replacement.  But with one disk you'll need to do another factory install, and reconfigure the NAS again.
ProSupport for Business
