abhassurana's avatar
abhassurana
Follower
Dec 09, 2017
Folders not showing after after power failure
hi all,
i am new to readynas. i copied all my music and pictures to NAS. few minutes ago there was a power failure. when my nas started back. my volumes are not showing folders. although when i check volumes it shows data in it. also when i tried to create a folder by same old name (the folder which is not showing) it is showing error saying cannot create as name is not unique.
can anyone help on this..
  • I always recommend getting a UPS for the NAS (and having the NAS monitor the power using the NAS USB connection).
    What firmware are you running on the NAS?
    The safest thing to do is start over with a factory reset, rebuild the NAS and copy the data again.  Is that practical?
1 Reply
  • StephenB's avatar
ProSupport for Business
