Lostandbemused
Nov 28, 2022Follower
Forgotten password ReadyNAS RN10200
Hi! It's been a while since I used my ReadyNAS RN10200, and I've forgotten the password. I see that there's already been a solution provided in this forum, but that involves doing an OS reinstall....
Nov 28, 2022Guru - Experienced User
Lostandbemused wrote:
I see that there's already been a solution provided in this forum, but that involves doing an OS reinstall. I'm afraid, however, that this will delete all the (many) files that I have backed up on the discs!
It won't delete your files. However, if these are the only copies of your files, then the NAS is being used for primary storage, and is not a backup. If that's your situation, you should look into solutions for backing up the NAS (for instance, using USB drives).
It will
- reset the admin password to password
- reset the network connection to use DHCP
- disable volume quota (which can be re-enabled on the volume settings wheel).
