fbmachines
Feb 15, 2012Guide
Forum Logo Missing
Is it just my privileges at work or is the ReadyNAS forum logo missing in the upper left corner?
mdgm-ntgr
Feb 16, 2012NETGEAR Employee Retired
That could be it. I'm using prosilver, not the old subsilver2. I stayed on subsilver2 for a while, but eventually decided to switch. Although the different look takes some getting used to, it has some nice features e.g. limits space on the screen taken up by stuff in code tags, so if you don't want to read it all you can easily scroll past it.
