chirpa
Mar 05, 2010Luminary
Forum Theme Change (subSilver2->proSilver default)
If you don't like this new default theme, you can revert to the older subSilver2 theme here: Board Preferences. Existing users will have their forum theme retained. You will only see the theme chan...
fbmachines
Mar 17, 2012Guide
Apparently it only happens with the older subsilver2 theme. The newer prosilver theme doesn't have a broken link to the image.
viewtopic.php?t=61230
