snowklein
May 30, 2010Aspirant
Frontview css error for background image
The relative path to the macFFBgHack.png is wrong. Either the css needs to change to point to ../images/macFFBgHack.png or the image needs to be placed in the theme folder. mainz:/frontview/ui/...
Darth_Vader
Aug 22, 2011NETGEAR Employee Retired
snowklein wrote: The relative path to the macFFBgHack.png is wrong. Either the css needs to change to point to ../images/macFFBgHack.png or the image needs to be placed in the theme folder.
mainz:/frontview/ui/resource/theme# grep macFFBgHack *css
thickbox.css:.TB_overlayMacFFBGHack {background: url(macFFBgHack.png) repeat;} /* Use /images/macFFBgHack.png if you need grayout background */
This is intentional because we are not showing grayout background. The comment indicates the correct path to use if you really want to show a grayout background when the loader appears.
Thanks
