frankseipferd
Oct 25, 2017Aspirant
No Cloud Backuop in the Background
Hallo, since a few Days, the Backup of my Media-Data about the ReadyCloud does no longer work in the Backgroud. If i close the Phone, the Transfer will be interrupting. Does everyone knew this Problem? Regards Frank
Which version of the app do you have installed?
Which smartphone OS version are you running?
- mdgm-ntgrNETGEAR Employee Retired
Which smartphone OS version are you running?- frankseipferdAspirantI use version 2.0.0 by the cloud app and ios 11.3 by the operating system
- frankseipferdAspirantMy problem is not solved yet.
