Xophile
Jul 28, 2011Aspirant
[FSP Group] [EP 450] - Compatible with Ultra 4?
Hi! Does anyone know if I can expect any problems with a simple UPS from FSP? EP450 is interesting considering the price but it's not mentioned anywhere. Thanks!
ReadySECURE
Aug 02, 2011Apprentice
Hello,
I have searched and do not see any entries about the UPS. The forums is the best way to find out and since there are no entries regarding that UPS it's hard to say. You can always test and let us know, I would recommend of course if you are purchasing specifically for the ReadyNAS that you know the return policy from the vendor, in case it does not work you can return it.
If you do purchase one to test please let us know the results.
Support Resources
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources
Forums:
Knowledge base
