dsm1212
Jan 30, 2021Apprentice
Full reinit procedure for Pro 6?
Had this Pro6 for years and it's worked great but I finally put together a newer box based on opensource and docker. Since this is still running I want to use it for backups. But there is a bad file ...
Jan 30, 2021Guru - Experienced User
A factory default will reformat the disks. Or you can remove the partitions with the NAS powered down - for instance by connecting the disks to a windows PC and deleting them with windows disk manager. The put them back in the NAS and power up, and it will do a factory install.
Sandshark
Jan 31, 2021Sensei
While a Pro6 running the original 4.2.x RAIDiator OS is still a viable backup, and even a usable main NAS for many, I believe the day will come, perhaps not too far off, that access will be more limited as the protocols used are further depreciated in Windows and browsers and made impossible to enable. So, since you are going to do a factory default, anyway, this would be a good time to decide if upgrading to OS6 is right for you.
- StephenBFeb 01, 2021Guru - Experienced User
Good general advice, but I think you missed that dsm1212 is already running 6.10.4.
- dsm1212Feb 02, 2021Apprentice
Right, thanks. As soon as I'm comfortable with the new system I'll give the full init a go. On that topic of OS6 though, it was great that you supported this so long. My pro 6 is 9 years old and still running! I only had replaced two failed disks. I do blow out the dust every year and replaced the thermal paste probably 3 times. I had also upgraded the cpu which was socketed and the memory. I did those the first week though :-). Overall it has been a very reliable machine. I've had 5 people using it pretty much continuously for backups and media (local and remote). The only reason I built instead of bought again is that I wanted to be on a current linux distro and the docker model for services is ideal. Docker is not for typical consumers but it is just just perfect for a small nas and a technical owner.
steve
- SandsharkFeb 03, 2021Sensei
While a user has made a Docker app available to ReadyNAS users, I do not understand why Netgear has not grabbed onto it as an alternative to apps. The ReadyNAS line is nearly devoid of app developers, but there are pre-made Docker packages all over. It has been in the Idea exchange for years, and Netgear even took credit for it being "implemented", which was quite a stretch of the truth since it's not their work, not integrated into the OS, and not easy for a typical user to implement.
I personally have a dual hex-core Xeon PC in the same rack as my NASes that I can use for most anything somebody would want an app for, so don't need it. But I know I'm not the typical case.
