dsm1212
Jan 30, 2021Apprentice
Full reinit procedure for Pro 6?
Had this Pro6 for years and it's worked great but I finally put together a newer box based on opensource and docker. Since this is still running I want to use it for backups. But there is a bad file ...
Sandshark
Jan 31, 2021Sensei
While a Pro6 running the original 4.2.x RAIDiator OS is still a viable backup, and even a usable main NAS for many, I believe the day will come, perhaps not too far off, that access will be more limited as the protocols used are further depreciated in Windows and browsers and made impossible to enable. So, since you are going to do a factory default, anyway, this would be a good time to decide if upgrading to OS6 is right for you.
