mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
dsm1212
May 02, 2015Apprentice
Pro-6 with 8MB memory and an upgraded processor
6.2.3 I encountered a weird problem with readynasd constantly crashing every 12 seconds after installation. Then it suddenly cleared up and didn't come back.
6.2.4 installed and updated fine. Only odd thing is that after the install reboot there were two instances of sickbeard running. There was no pid file in /apps/sickbeard. I killed them and restarted and everthing was OK. Not sure how that happened and I hadn't seen it before. Might have been difficult for someone without ssh access.
Overall things are working pretty well. I have a fairly complicated openvpn setup and that survived the transition without incident. All of my apps continued to work fine.
