mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
paltrude
May 02, 2015Aspirant
Running 6.2.4.
Moved from 4.2.28 [T6] yesterday and everything runs fine. The firmware installed itself smoothly and I had already bought a 2GB of RAM for my Ultra 2 (RNDU2000) years ago which could help the new interface?
I do however notice an increase in heat, the disks keep at 42-44 degrees Celsius (as before) but the CPU went from 54 to 70 degrees idle at 800 rpms, and under heavy load it pushes 80 degrees at 1200 rpms.
The fan runs quietly though, as it did before. Does it need to be tampered with?
http://www.readynas.com/forum/viewtopic.php?f=110&t=52557&start=15#p364381
