mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
paltrude
May 02, 2015Aspirant
dsm1212 wrote: 70-80 deg C is pretty hot for a cpu temp. I'd probably try cleaning the cpu fan. I'm not familiar with the ultra 2 though. It is the CPU temp you are seeing and not the case temp right?
steve
Already done that, didn't seem to do the trick. Besides, just hours before it reached mid 50 idle (under os 4) so unless I am incredibly dusty, that should not be the problem.
In OS6, under performance, the CPU temp is measured at 77 degrees Celsius under heavy load with the fan at 1200 rpms. Is it measuring something else?
I don't recall the temp under radiator but I do know it never reached above 60 degrees Celsius under heavy load.
