mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
paltrude
May 03, 2015Aspirant
Mhm, I had thought about asking that actually.
Should I be more concerned? Switch back to Raidiator 4.2.28+?
The Ultra 2 (albeit with 2 GB RAM) works great with OS 6 as far as my usage is concerned, I would just like to avoid having to replace it because of accidental frying of components...
It seems to have a CPU temp between 70 and as high as 80C but then it went down to 70 almost directly, the SYSTEM temp around 33C, the disks are 44 and 42 respectively (as before btw).
Should I try the fan control script I read about in http://www.readynas.com/forum/viewtopic.php?f=160&t=71155 and see if I can get the CPU temp down?
I am quite unfamiliar with ssh and such, so pointing me towards a "how to" would be great.
