mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
mdgm-ntgr
May 13, 2015NETGEAR Employee Retired
cpu8088 wrote:
still the warning of 70% full is showing in the log. this is annoying.
i have been assured that 70% full post no prob.
The whole point of warning before there is a problem is to alert you that it would be good idea to take action to expand the volume or free up space.
If we only start warning when there is a problem then that doesn't help with avoiding running into problems.
timfitz wrote: I've had two clients update their own ReadyNAS devices to 6.2.4 on their own and lose their Egnyte storage sync share access after the update
After a firmware update, an app developer may need to update their app for it to remain compatible so if an app is very important to you it would be a good idea to check with the app developer that they've tested it and found it to be working on new firmware before doing the firmware update.
timfitz wrote: BTW: is there a way to disable the nag screen for updating the firmware? Or like set it to check every x months? Sometimes users need to log in to do basic admin tasks like add or remove new Egnyte users, and the update nag is apparently just super tempting. Alternate solution would be a non-admin interface for users to do this, or a sub-admin management role, I suppose. The user story here is, I would like to be able to switch from automatically to manually checking for updates. (Found some info about such a feature for v4 but not yet for v6.)
I don't think there is a way to disable the prompt currently. As you mentioned you don't have to agree to do the update. Generally I would encourage users to use the latest firmware as it will provide the best experience in most cases.
