mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
SurplusGadgets
Jun 17, 2015Aspirant
Thanks mdgm for the help last night. It appears it is not the disk, which does have reallocation errors, but the memory. This would better explain the corruption of the btrfs whole volume. And the corruption I was still investigating when I recreated the filestore after upgrading to all 4TB disks earlier this year. Boot Menu memory diagnostics is picking up many memory errors. Sure wish the user could get into the system like you can in Diagnostic mode to do self evals. Anyway, thanks for the help and the attempt to see if data could be saved. Odd that the issue took a firmware upgrade to present itself more dramatically. FYI, is there a better way to see memory results than the front panel? Neither 4.3.8 nor 6.0 RAIDar detect the device in this mode. And SSH and HTTP are not enabled, as expected. Disktest on the front panel seemed to progressing. But when I came back hours later, it no longer showed a percentage and simply listed "Testing Disks" -- as did RAIDar (both versions). This never went away as much as 12 hours later. So never really got results for that Boot Menu test either.
