mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
mdgm-ntgr
Jun 17, 2015NETGEAR Employee Retired
I don't think you can view the memory test progress over your network. The front panel is the way to view the progress/results.
The memory issues probably explain why the disk test didn't complete if it hung. The results for that test are in the SMART extended test history for the disk which you can check using SSH.
