mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
Kardano1
Jun 20, 2015Guide
I updated 2x RN102, 1 RN104, 1 RN314. On all RN102 and RN314 units with 6.2.4 FW (and AV plus and SMB plus) IF antivirus definition update fail (log: System: Antivirus scanner definition file update failed. (error code: 5)) it causes complete shutdown antivirus function. It is necessary personally log on and switch ON antivirus through the admin interface to restore it's function. In summary page is showing geen dot and last AV definition version, BUT NOT that AV is disabled! When you check it - click on AV definition version(offer you enable AV, box is not checked) or in settings tab (Antivirus is without green bar indicating it is disabled). If you open Antivirus plus it is showing correct that AV IS disabled.With older FW versions after update of AV definitions failed,antivirus stays ON and try update later again. I think that old way is correct. With new settings (AV turn off itself) is AV not usable without permanent supervision over NAS.
EDIT - i moved defrag problem with RN104 to new thread (thanks StephenB for advice)
http://www.readynas.com/forum/viewtopic.php?f=10&t=81464
