mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
General Feedback on 6.2.3/6.2.4
This thread is a place to leave general feedback on 6.2.3/6.2.4
Jul 10, 2015Guru - Experienced User
I also connect this way, and this problem has been therefore a couple of releases now. It would be nice to get it fixed.
Jophus wrote: Small issue, but landing page app-installed icons don't work when used on non-standard port (I have a high range port >40000 to connect to secure web interface. Inspecting the elements which make up the links to the icons I see: <img width="64" height="64" src="https://ipaddresshidden/apps/logo/lms.png" id="ext-gen431"> (ip address hidden) with no reference to the port number needed to connect... should this not be ipaddresshidden:40000 or similar (in my instance).
