sleepy06405
May 20, 2012Aspirant
Get back up to 50 GB missing space
WARNING: Using the information in this post WILL lead to denial of support and possibly void your warranty. In addition you may lose a good nights sleep if something goes wrong. Basically don't try th...
Dewdman42
May 20, 2012Virtuoso
Very interesting. That sort of explains the answer to my question here: http://www.readynas.com/forum/viewtopic.php?f=65&t=63337
Although its not clear to me yet why this 50gb of reserved spaced is not included by "df" report.
At any rate, 50gb of reserved space for root to be able to write to some logs should the os partition fill up, seems like a LOT of wasted space, but I definitely need to understand the complete ramifications of that before reducing it. Thanks a lot for this tip though! I guess this would definitely be a warranty ending configuration. ;-)
