sleepy06405
May 20, 2012Aspirant
Get back up to 50 GB missing space
WARNING: Using the information in this post WILL lead to denial of support and possibly void your warranty. In addition you may lose a good nights sleep if something goes wrong. Basically don't try th...
Dewdman42
May 20, 2012Virtuoso
oic. it doesn't show the space as used, but the available is lowered. Interesting. Its truly hidden in some little kernel corner I guess, where df can't see it, but it can see that there is less space left.
On the other hand, I have 3TB drive, its going to be a while before I need that extra space and frankly if the free space is getting that low I should probably expand my raid by then anyway. In some ways, having that 50gb reserved space available to keep linux happy is not a bad idea. I've read that some programs can easily fill up /var/log on the readynas's 4gb os partition, particularly if you're using something that is not a well crafted addon package.
