federico_vitali
Dec 16, 2011Aspirant
Gigabit direct connection Intel 82566 DC 2 & Vista
Hi everyone, does anybody have configured a direct connection between a PC with network card Intel 82566 DC 2 with Windows Vista and a Ready NAS NV+ ? After a few minutes of slow speed conneci...
federico_vitali
Dec 17, 2011Aspirant
Dear PapaBear, thank you very much for your attention!
I answer to your questions below!
I'm using the cable that comes with the NAS, is it reliable?
If not, can you suggest me a known good cable?
I've never had problems with the nic of my PC, but I've never used it at 1 GB / s !
The NV+ is pretty new, I've bought it in july, but not used it very much.
When the NIC is working there is a fixed yellow light and a blinking green light for network activity.
As soon as it blocks again I tell you what it does when it's blocked.
I tell you one more thing that I think is important: these are the network errors of my NIC:
Errori di rete [Ethernet 1]
Negoziazione automatica 7
Pacchetti danneggiati 0
Disconnetti 0
Portante False 7
Errori inattività 255
Errori di collegamento 0
Errori di ricezione 179
Errori di simbolo 15
Tag VLAN 0
Ritrasmissioni TCP 23
Ritrasmissioni TCP non recuperate 15
And I ask you some more questions: what should be the approximate speed of file transfer with a GB direct connection?
Can I use Jumbo frame with direct connection? Would a GB switch give more speed than a direct connection?
Thank you very much in advance!
Have you tried a known good cable?
Have you had any other network connection problems with this NIC?
How old is the NV+?
What lights are lit on the NIC ports when you first start and are the still lit when the NAS goes off line?
Disconnetti 0
Portante False 7
Tag VLAN 0
