federico_vitali
Dec 16, 2011Aspirant
Gigabit direct connection Intel 82566 DC 2 & Vista
Hi everyone, does anybody have configured a direct connection between a PC with network card Intel 82566 DC 2 with Windows Vista and a Ready NAS NV+ ? After a few minutes of slow speed conneci...
Dec 17, 2011Guru - Experienced User
The cable Netgear ships should work fine. Though cables can get damaged, so if you have another ethernet cable it is worth a try.
federico.vitali wrote: I'm using the cable that comes with the NAS, is it reliable? If not, can you suggest me a known good cable?
The two Ritrasmissioni errors at the bottom are not too unusual, but everything else should be 0. I suggest that you try clearing the errors and do another test, and report the new error counts. Some of these errors might be due to disconnecting/reconnecting the ethernet or restarting the PC.
federico.vitali wrote: Errori di rete [Ethernet 1]
Negoziazione automatica 7
Pacchetti danneggiati 0
Disconnetti 0
Portante False 7
Errori inattività 255
Errori di collegamento 0
Errori di ricezione 179
Errori di simbolo 15
Tag VLAN 0
Ritrasmissioni TCP 23
Ritrasmissioni TCP non recuperate 15
You should be seeing transfer speeds between 25-40 megabytes per second for large file transfers. (http://home.bott.ca/webserver/?p=363)
federico.vitali wrote: what should be the approximate speed of file transfer with a GB direct connection?
Yes, but you should first get the basic connection running before you try that.
federico.vitali wrote: Can I use Jumbo frame with direct connection?
No. Nothing can be faster than the direct connection. However, a good switch will not slow it down either. Most people would use a switch, and generally would only use a direct connection for troubleshooting. The switch allows multiple devices (PCs, media players, the NV+, etc) to connect with each other. It also allows them all to connect to the internet.
federico.vitali wrote: Would a GB switch give more speed than a direct connection?
