federico_vitali
Dec 16, 2011Aspirant
Gigabit direct connection Intel 82566 DC 2 & Vista
Hi everyone, does anybody have configured a direct connection between a PC with network card Intel 82566 DC 2 with Windows Vista and a Ready NAS NV+ ? After a few minutes of slow speed conneci...
PapaBear1
Dec 19, 2011Apprentice
That test would be a good idea. It would be a change, and if it goes away, you have your culprit. It is unfortunate that sometimes we had to resolve network problems by the process of elimination, but at times it is easier to do.
Looking back over the thread in your initial post you asked if anyone had a direct connection between the Intel chip and the NV+. Does this mean you are running a direct connection when you are getting the lock up. If so, then you only have three possible culprits - the PC, the cable and the NAS. Once you have swapped out two of them, and the problem remains, then the culprit is the third one.
