steveoelliott
Jul 05, 2013Luminary
Hard Drive Caddy
Hi, I have 4 HDD caddy's from my old NV+. Does anybody know which units these may fit? Thanks...
Jul 05, 2013Guru - Experienced User
The NV+ v1 caddies will also fit in the duo v1, the NV+ v2, the duo v2, the ultra and pro desktop products. They won't fit the new RN1xx, RN3xx, RN5xx products, and they won't fit any of the rack-mount NAS. BTW, they also fit the EVA9150 media player.
steveoelliott wrote: I meant the caddy not the disk itself.
The older caddies have round buttons, and are prone to jam. Newer ones have square buttons and don't have that particular problem.
If these caddies are surplus (for instance, from a failed NAS) make sure that you don't lose the mounting screws - replacements are hard to come by.
Like mdgm, I am wondering why you are asking.
