steveoelliott
Jul 05, 2013Luminary
Hard Drive Caddy
Hi, I have 4 HDD caddy's from my old NV+. Does anybody know which units these may fit? Thanks...
Jul 05, 2013Guru - Experienced User
Good to know. I thought I asked this before, and was told the old caddies wouldn't work. I didn't try it, as I didn't want to risk damage to the drive SATA connectors
mdgm wrote: StephenB they should work in the new desktop models. It's just the new screwless drive trays will only work in the latest models.
Anyway, I wouldn't re-use the round-button caddies unless I had no choice - several of mine consistently jam, and releasing them with a paperclip is annoying.
