tin008
Nov 22, 2012Aspirant
Hard Drive Compatibility for NV+ 2 ..
Hi, I have a few questions about the HD compatibility list on the NV+ 2 . http://www.readynas.com/?page_id=82 It seems to me that the list for the NV+ 2 is not so update. Some of the drives on...
Caustic
Nov 24, 2012Aspirant
From what I hear, if it isn't on the official list, I wouldn't suggest taking the risk. Even if the model numbers are very similar, that doesn't mean the drive inside isn't quite different. Seaching on the forums for anything you plan on buying is always wise.
