phmougin's avatar
phmougin
Follower
Sep 18, 2013
hard drive compatible for modele RNDP6310
i would like to know which hard drive 2 TB are compatible withe the netgear businness pro RNDP6310
for example Seagate Desktop HDD 2 TB mod STX-ST2000DM001 ?
the compatibility list on netgear site is not update!! some hard drive does not exists anymore...
thank you for your answer
1 Reply
  • StephenB's avatar
    I agree it that the slow updates to the HCL is frustrating. Though keeping old (but compatible) disks on the list is needed, since many existing customers have those disks installed.
    Remember that Netgear can/will deny support for disk-related issues if you use disks that aren't on the HCL.
ProSupport for Business
