cat509
Mar 27, 2013Tutor
Hard Drive Question
I have a ReadyNas Duo and I want to purchase a ReadyNas Ultra. Can I take the hard drive from my Duo and put it in the Ultra and keep all of the data on it?
mdgm-ntgr
Mar 27, 2013NETGEAR Employee Retired
No. The RAID format is different. You will need to transfer your data across your network.
Have you considered the new ReadyNAS 312 and 314 which will be available soon?
