cat509
Mar 27, 2013Tutor
Hard Drive Question
I have a ReadyNas Duo and I want to purchase a ReadyNas Ultra. Can I take the hard drive from my Duo and put it in the Ultra and keep all of the data on it?
Mar 27, 2013Guru - Experienced User
Though the ultra is (in my view) still a nice choice, you should probably also consider the RN314 launched earlier this month. That will also wipe the drive, so there's no change there. It is a bit more than the ultras (which are heavily discounted at the moment as retailers are clearing inventory for the new models).
You can preorder in the US (http://www.newegg.com/Product/ProductLi ... as&x=0&y=0)
There's also some information here: http://support.netgear.com/product/RN31400
