Draax
Mar 07, 2014Aspirant
Harddrive Question
Hello, I have a question about the harddrives outside the Netgear nas. Im running raid 1 on 2 drives, is it posible to remove one drive and plug it into my computer to access the data (running windo...
Mar 07, 2014Guru - Experienced User
You will need software - windows does not recognize the drive format.
Linux Reader works with the v1, I don't know if it also works with the v2. http://www.diskinternals.com/linux-reader/
