Draax
Mar 07, 2014Aspirant
Harddrive Question
Hello, I have a question about the harddrives outside the Netgear nas. Im running raid 1 on 2 drives, is it posible to remove one drive and plug it into my computer to access the data (running windo...
Mar 07, 2014Guru - Experienced User
Shut down the NAS, especially don't hot-insert after you try this. The NAS will wipe the drive and then rebuild the RAID array if you do that.
