miogpsrocks
Nov 25, 2015Tutor
Has anyone modified UPS to use a car battery?
I am sick and tired of my power going out and readynas getting a harsh shutdown. My power system in my area is actually worse than a 3rd world country. The power is constantly going out for ho...
mdgm-ntgr
Nov 25, 2015NETGEAR Employee Retired
That sounds like something that would be very dangerous.
You are best to ask an expert on UPS systems (and other systems) about an appropriate solution for your environment which takes into account your regular lengthy power outages.
miogpsrocks
Nov 25, 2015Tutor
- StephenBNov 26, 2015Guru - Experienced User
You can daisy-chain a couple of UPS to get longer run time.
A generator is of course another option, which could provide power for the house generally.
- pdasterlyFeb 04, 2016Guide
not just any car battery, you need a AGM sealed battery, regualr car batteries need some where to vent and will release poisionous gas if not vented properly
