boblam
May 03, 2012Aspirant
HCL X6 - Disk Drives
I have an X6 and one of the disks is failing. It doesn't appear that the HCL lists drives for the X6 (RAIDiator 4.1.7). I stayed on that version of RAIDiator as the newer version caused performance ...
chirpa
May 03, 2012Luminary
The 600 would share the HCL with the NV+ as mdgm mentioned.
Seagate doesn't provide Linux utilities to flash hard drive firmware. You would have to connect them to a PC and use a DOS boot disk most likely.
