ardea
Jun 09, 2017Aspirant
HD Compatibility Question
We have 2 NV+ presently each filled with 4 x 750 GB Seagates . We need to upgrade to the maximum 4 x 2TB. Their HCL contains many unobtainable disks. This post: https://community.netgear.com/t5/R...
Sandshark
Jun 09, 2017Sensei
Yes, the WD Reds up to 2TB are an excellent choice for the NV+.
- StephenBJun 09, 2017Guru - Experienced User
Unfortunately Netgear stopped adding to the HCL for the legacy ReadyNAS quite a while ago.
I also recommend the WD20EFRX in these NAS. I have one in my Duo v1, and it works well.
