Mrk74
May 14, 2018Aspirant
HD resyncing on Ultra 2 takes >100 hours after upgrading to OS6?
Hi,
Yesterday I updated one of my ReadyNAS Ultra2's to OS6, just as decribed here:
http://netgear.nas-central.org/wiki/OS6_on_Legacy_x86
The upgrade to OS6 was succesfull, however 1 of ...
May 15, 2018Guru - Experienced User
It sounds excessive (and the estimate might not be right). Perhaps let it run to completion, and let us know how long it actually takes.
bedlam1
May 15, 2018Prodigy
Did you check/update your Bios in 4.2 before upgrading?
- Mrk74May 15, 2018Aspirant
Hi,
I checked the firmware before updating to OS6.
The firmware was v1.8.
the resyncing process is around 20% now after 24 hours.
- bedlam1May 15, 2018Prodigy
Can you download your logs using GUI or Raidar and look in bios_ver.log the important piece of info is the /sys/class/dmi/id/bios_date
although for completeness please post /sys/class/dmi/id/product_version & /sys/class/dmi/id/bios_version too.
As an EDIT I believe the current Bios date is 11/02/2011
Hi Bedlam1.
This is the info:
11/02/2011 ReadyNAS-ProUltra2 V1.8/sys/class/dmi/id/bios_date
11/02/2011/sys/class/dmi/id/product_version
11/02/2011 ReadyNAS-ProUltra2 V1.8/sys/class/dmi/id/bios_version
080016
