funglenn
Feb 12, 2017Luminary
Help /dev/md0 is full
Help, my primary parition is filling up--it sent me an email and this is what I see: What is the /dev/md0? root@ReadyNAS:~/VirtualBox VMs/Windows10_64/Logs# df Filesystem 1K-blocks Used Availab...
bedlam1
Feb 12, 2017Prodigy
What is the /dev/md0? It is the OS system partiton for your NAS, it is only 4GB and typically should be no more 30% full
Go in with SSH and run df -h and df -1 and post results
I suspect you have installed something there instead of in the data partiton or something is saving log files there, you need to get rid ASAP or you will be having to perform a Factory Default to recover
funglenn
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.5G 157M 96% /
tmpfs 1.9G 24K 1.9G 1% /dev/shm
tmpfs 1.9G 6.2M 1.9G 1% /run
tmpfs 959M 0 959M 0% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/md126 7.3T 4.6T 2.7T 64% /data
/dev/md126 7.3T 4.6T 2.7T 64% /home
/dev/md126 7.3T 4.6T 2.7T 64% /apps
- funglennFeb 12, 2017LuminaryFilesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 3.5G 157M 96% / tmpfs 1.9G 24K 1.9G 1% /dev/shm tmpfs 1.9G 6.2M 1.9G 1% /run tmpfs 959M 0 959M 0% /run/lock tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup /dev/md126 7.3T 4.6T 2.7T 64% /data /dev/md126 7.3T 4.6T 2.7T 64% /home /dev/md126 7.3T 4.6T 2.7T 64% /apps ilesystem 1K-blocks Used Available Use% Mounted on udev 10240 4 10236 1% /dev /dev/md0 4190208 3668688 160432 96% / tmpfs 1963928 4 1963924 1% /dev/shm tmpfs 1963928 6324 1957604 1% /run tmpfs 981964 0 981964 0% /run/lock tmpfs 1963928 0 1963928 0% /sys/fs/cgroup /dev/md126 7789422656 4918553848 2863483208 64% /data /dev/md126 7789422656 4918553848 2863483208 64% /home /dev/md126 7789422656 4918553848 2863483208 64% /apps yes, but how do i find out what to remove?
i found the one VM snapshot--deleted the 1.6G file and the system went from 88% to 45% full.
crisis averted!
thanks all
- bedlam1Feb 12, 2017Prodigy
AFAIK 45% is above average usage, have a look at the posts shown under "recommendations" to the right of your initial post for advice on finding more culprits
